I want to analyze the clearance of a pushing propeller and stresses. I have seen that I should use RFORCE to simulate centrifugal force but I don't know how could I combine that force with the pressure on the blade. When the static analysis is defined I have choose either PRESSURE or RFORCE. I can't use superposition as RFORCE doesn't make any difference in the flexion of the blade until some deformation from PRESSURE occurs.
How could I combine both?
