I have carried out the "OS-T: 1325 Random Response Analysis of a Flat Plate' tutorial, to mimic the real time project. However, I could not understand the steps used in the analysis as there was no explanation. It is quite difficult follow & carry out the analysis unless clear explanation in provided for each step. I request you please share the example with clear explain of each step logic behind each step.
