Selection of Cross section
Arvind_20679
Arvind_20679 New Altair Community Member
edited January 2023 in Community Q&A
Hallo
I  am working  in Aerospace  for SA.
For a Frame Structure  ( from 3D-drawing), each element has 12  cross sections.  f
From that I need to select a best cross section  and worst case cross section. Everytime, I open the .stp file and look the section and get the properties  and select the best and worst case... it is bit time consuming..
Do Altair , help me with some automation. (any code file), so that I managewith it..
Attached couple of sketches
Thanks
Arvind Gopalrathnam
  • Adriano_Koga
    Adriano_Koga
    edited January 2023
    Have your tried HyperStudy? Or maybe even Design Explorer?
    Assuming that you're running a 1D model, with these, you could just create your 12 cross-sections and then bring your .fem file to HyperStudy and request it to change your PBEAM cross-section to a different one, and run your model, selecting the best section based on some criterea.
    It would be something like:
    .fem file
    #model..
    #properties
    PBEAM,ID,MAT_ID,.... cross-section_1
    PBEAM,ID,MAT_ID,.... cross-section_2
    PBEAM,ID,MAT_ID,.... cross-section_3
    from there, HyperStudy could turn it into a template, and change the PBEAM data to something else, by generating a template.
    I'm not sure if this is what you're looking for, but it might be helpful.
