could someone help me in meshing a sphere with regular hexa elements?
I want to obtain the following result, with all elements having the same size.
Thank you for your help.
Andrea
Hello Frederic, thank you for your help. It seems easier in HyperWorks. Could you please provide the steps also in HyperMesh 2022.1? I tried with HyperWorks 2022.1 but I see from your video you are doing it in the 2023.1 and in my version I cannot find the design space ribbon and voxel mesh. Regards, Andrea
Hello Frederic,
Hi Andrea,
Design Space ribbon should also be available in 2022.1. But, as this workflow is to support topology optimization model build and setup, it is only available for the OptiStruct solver interface. Maybe that's why you can't find it.
Fred.
Hello Andrea,
If your goal is to get perfect cube elements, then I would say the best approach is to create a voxel mesh from the Design Space ribbon. Please find attached a quick video highlighting this solution.
Regards,Fred.
Hello Andrea, If your goal is to get perfect cube elements, then I would say the best approach is to create a voxel mesh from the Design Space ribbon. Please find attached a quick video highlighting this solution. Regards,Fred.
Hi Andrea, Design Space ribbon should also be available in 2022.1. But, as this workflow is to support topology optimization model build and setup, it is only available for the OptiStruct solver interface. Maybe that's why you can't find it. Fred.
Indeed, problem solved. Thank you very much for your help.
