Is it possible to stop a Radioss run, change the frequency for animation files in /ANIM/DT in the engine file and restart the run?
Will this improve the run time?
Thank you in advance!
Yes, you can use different animation /ANIM/DT in a restart run.
Reducing the frequency of recording may have benefit if you are saving lots of data on each animation.
I hope this is helpful.
Regards
Yes, you can use different animation /ANIM/DT in a restart run. Reducing the frequency of recording may have benefit if you are saving lots of data on each animation. I hope this is helpful. Regards
Thank you, Rogerio!
Could you quantify "lots of data" on each animation? At the moment each animation file I have is 89845 KB.
