Dear sir
I appreciate to the previous replies. As direct shear test apparatus is sent in the appendix I need an edem python code for post processing. I changed the edem python code for generic shear test and used to get the result but I have an error yet and cannt get any result. If anyone can help me and check the apparatus of direct shear test and also the python code created for this test really appreciate. I need help to get thus result.
Sincerely yours
Hi Abbas,What is the error that you see in this case?
Regards
Stephen
This is the error picture in attachment when I run the changed code for direct shear test. If you help me to check the code for direct shear test you save my future. Again I send error picture of code,direct shear test apparatus and direct shear test python code and setting for it.
Best regards
Hi Abbas,
Could you share the simulation deck you're using?
Best regards,
Renan
