Hi everyone,
is there a way to have two different 2D meshes with the same number of elements?
Are you asking if this is possible or this is something you want to achieve?
Absolutely you can have two totally different meshes with the same number of nodes/elements.
It all depends on the pattern of the elements.
Could you please add a bit more information to your question?
Hello, Are you asking if this is possible or this is something you want to achieve? Absolutely you can have two totally different meshes with the same number of nodes/elements. It all depends on the pattern of the elements. Could you please add a bit more information to your question?
