When InstallAnywhere has finished preparing the installation, it finishes and reaches 100%, but then the feko installer doesn't appear. Nothing happens after it has finished.
It is possible that the executable/s was corrupted on download and hence you will need to completely uninstall the software and re-download the executable. It is important to first try deleting the downloaded file and downloading it again.
If you still face issues, to make sure the file is not damaged on download, run an md5 checksum on the downloaded file (just google md5 checksum):
Refer this to identify correct MD5 value - https://community.altair.com/community/en/checking-a-downloaded-installer?id=kb_article&sysparm_article=KB0117361&sys_kb_id=5e2d7fc8db8b9950cfd5f6a4e2961925&spa=1
Thanks.
It still does not work, is it not possible to try with other older versions?Thanks.
Can you share MD5 value here?
