I have 100 odb files and intend to calculate the received power of these networks using Winprop API. I have perused the documentation and attempted to execute the C++ sample named 'outdoor_propagation'. However, the sample is using an opb file. How do I get an opb file?
Thank you,
Tianhang Yu
Hi,instead of the preprocessed .opb file you can also use the raw .odb file in the API.
You just need to adapt the GeneralParameters.BuildingsMode from BUILDINGSMODE_UDP to BUILDINGSMODE_BINARY. Please see the #defines in OutdoorPlugIn.h.
Best regards
Reiner
Hi Tianhang,
An .opb is a preprocessed outdoor database for the UDP model prediction. You can preprocess your odb files and you'll get the corresponding .opb s
BTW, you can either run UDP with a preprocessed database or not.
Zeina
