I have successive message during my run : "WARNING ZERO OR NEGATIVE SUB-VOLUME : 3D-ELEMENT ID : 29874885 ELEMENT IS SWITCHED TO SMALL STRAIN OPTION"
and at the end the run is killed with the message : "MESSAGE ID : 207 ** RUN KILLED : TOTAL MASS ERROR LIMIT REACHED".
What is exactly the signification of the first message ? I thought that it is necessary to choice the option Ismstr 2 for 3D tetra element in the property to switch in small strain formulation. I did not used this option, I kept the Ismstr 0 (default value) but I have this message.
Why is my run killed ?
Thank you in advance for yours answers
