How to infer from license log file?
Nagesh_20635
Nagesh_20635 Altair Community Member
Hello support team,
  I am looking at the log file where i could see the feature Check out and check in times. But it is not mentioned which instance of a specific feature is checkout or closed .
For example if a user opens two hypermesh( second instance happens after an hour of first instance )and check in and check out times for that is recorded in the log file. But Check in times recorded in the log file does not specify whether it is first instance or first instance .
Is there any method to figure out Check in times correct?
Welcome!
Welcome!
