Can someone shed light on 'Save Geom in Database', or not?
I've had weird things happen when Checking this box, with zillions of apparent faces being imported rather than solids. But then it didn't repeat. Next time just the solid bodies.
Which database? The model.slb file or a database somewhere else.
It does not appear I should ever need to check that box, based on successful imports.
