i need to apply a equation for a analisys of a tube.
The equation is :x^2+x+15.And the x is a distancia in meters.
I know that have a place called equation.
But i don´t know how to use it.
Hi @tiago3008
What is this equation about?
Is it a response for optimization?
You can create the same in Equation if it is a response using EQUATION in Analysis>>Optimization and link the same using Function in response.
Refer to this below post where another user creates a relative displacement response using equations
Hi, i need to apply a equation for a analisys of a tube. The equation is :x^2+x+15.And the x is a distancia in meters. I know that have a place called equation. But i don´t know how to use it.
An equation must have 2 sides relating by comparing operator
Please provide it correctly
An equation must have 2 sides relating by comparing operator Please provide it correctly
I dont know I need how to use dequation and dresp2 properties
You mean that you want to apply a pressure for example such as : P = x^2+x+15 ?
no I can enter an equation at dequation
but I cannot define response from function
