Hello, Jose,
Thank you for reaching out. You can click the "Default" button on the right side of the "Analysis Type" window to reset the settings to default, and then modify the parameters according to your needs.
Alejandro Lopez
Altair Support
Hello, Jose, Thank you for reaching out. You can click the "Default" button on the right side of the "Analysis Type" window to reset the settings to default, and then modify the parameters according to your needs. Regards, Alejandro Lopez Altair Support
Hello Alejandro,
I'm doing a linear static analysis, the "default" buttom doesn't work for that mode of analysis.
This is the first time i got this message for a linear static analysis.
What shoul I do then?
Thanks,
