Optistruct is conducting an analysis instead of an optimization for composite size
User: "Matthias Taubert"
Altair Community Member
Updated by Matthias Taubert
Hello Altair folks,
I got a question. I set up a composite size optimization for a door structure. But when I want to run it, the solver only conducts an analysis, stating ANALYSIS COMPLETED at the end. Can someone help? Run option is of course "optimization"
Best Regards
1 - 1 of 11
    User: "PaulAltair"
    Updated by PaulAltair
    Are you sure you have the optimisation variables set (correctly), are there any messages in the out about 'no optimisation variables found'?
    If you can share your .hm we can take a look, if you can't share the .hm, then the .out file would give us more to go on
