I am trying to do topology optimization of a wheel, but i don´t know how to optimize step by step.
I saw some webnars but i did not get clear information to my case (wheel).
Have a look at Optimization tutorials of Hyperworks. I found them understandable and helpful.
i saw some tutorials but i don´t know what i did but the result is the same always.
The graph don´t change.
and the result is the same too and very strange for a wheel.
I can see that there is an objective function but no constraint on design. I think this is the reason for such a design at the end of optimization.
If you want to add stress constraint I suggest you to add through Topology panel>> Parameters>> Stress constraints.
If you still have problem, please share the model file with us.
