Can I change the port that Feko/WinProp uses for licensing when contacting a licence server from 6200 to a different value?
You will need to change the port on which your license server is listening. The steps are detailed in our Altair License Management System Guide.
Thanks,
Matthieu Pupat
Thank you, I will go and read the guide!
Hello, You will need to change the port on which your license server is listening. The steps are detailed in our Altair License Management System Guide. Thanks, Matthieu Pupat
hi,
i download the pdf guide,but i don't found which pages that changing port value,can you directly tell me which page.
hi, i download the pdf guide,but i don't found which pages that changing port value,can you directly tell me which page.
It is very easy to find with Ctrl+F, anyway page 6 contains the necessary information.
