Opposite Force direction in bolts with the same load
Hello everybody,
I am an undergrad mechanical engeneering student and currently I am working on my bachelors thesis. In this process I ran into an problem with the simulation of a construction I have to analyse. Unfortunately I am not allowed to publich the whole model, so I reproduced the results in a MWE:
As the question title suggests, my interest lays in the bolts.
I modeled the connection using 1 RBE3 Element per hole and then connecting the RBE3s with an HYPERBEAM solid circle bar, which property is an PBEAM card. As orientation I used the y-axis, and i checked the elemental coordinate axes to face the same way.
I used the ELFORCE Output card to display the forces in the bolts. On solving and reviewing the results, the magnitude is eaqual. Unfortunatly, the results for Element Forces in the y-direction is calculated as facing different directioins, but having the same absolute value:
Because of these results I can't really trust the simulation, because that seems highly unlogical to me. If anyone could help me out with this, I would be very grateful.
Kind regards
Marius
Best Answer
Hi
I think it happens because the two CBEAM are oriented in same direction.
The end a or node N1 displacement/deformation relative to end b or node N2 is that is calculated.
So for the two cbeam , in each of them, the end a moves in opposite direction relative to end b.
Therefore, from the perspective of element result, the force is in opposite direction.
To be clear, this is element force, it is not spc force.
I hope this is helpful
Regards
Hi
Regards
0 -
Rogerio Nakano_21179 said:
Hi
Regards
Thank you very much! That solved the problem!
Now my ELForce in Z are orientated in different directions, but at least I can have trust in my simulation now.
Thankfully,
Marius
