Hi everyone,
I tried to run the tensile test using Radioss. I followed the method and setting from the tutorial file (RD-T: 3500 Tensile Test Setup).
1. When dealing with the flat specimen (as in the tutorial), the analysis gives a good result.
2. I tried to use the round specimen (change the property to P14_SOLID card image). however, the result shows that the specimen does not break. It continues to stretch until the final time. Based on the force versus time graph, the specimen already breaks at T20.
Really appreciate help from other users regarding this problem.
Thank you.
Attached is the image of the result.
Image1= flat specimen
Image2= round specimen T40
Image3= Force vs time
Image4=round specimen T20
Image5= round specimen T20.5
