MATS1 elasto-plastic
Hello all,
I know this question has been addressed in some past questions, however I would like to know if the the values of the true stress = sigma_nominal(1+strain_nominal) versus plastic strain = strain_true_total-(true stress)/E, where: strain_true_total = ln(1+strain_nominal), E = Young's modulus are entered into the tables1, or the values directly from the experimental stress-strain curve are entered. I am asking about the case of an elastoplastic material, with the table defined in terms of the plastic strain and the presence of large deformations.
Thank you.
Hi @mvass
Since you are interested in large deformation analysis, please use True stress-strain curve instead of the experimental curve,
Experiment results are engineering stress-strain curve and it needs to be converted to True stress-strain when using in MATS1
0 -
Thank you for the quick reply. It's exactly what I expected.
Regards
