Hi i have a simulation of an airfoil being damaged by an object, i need to export the Hyperview damaged mesh to hypermesh so i can create something to export as a cad to be able to run cfd on it.
I tried following steps from another forum post: "
- You need to first export deformed shape from HyperVIew (file > export > deformed shape)
- Import this file into HyperMesh
but when it comes to export it i dont know what to select, the only thig that ive been able to export is a file ".dat" that when i try to open it on hypermesh displays "Warning: Unsupported cards found in the I/O options section have been written as unsupported control card.
Summary:Feinput finished with 0 errors and 1 warnings."
It would be very helpfull if someone could give me a solution.
