Hello Team,
I am working on radial outer rotor motor. Do you have any example to follow? other than axial flux motor
Snehal.
The simplest way to build it would be to start from FluxMotor to save time. Then if you need a 3D model, you could import the FLU project in 3D and extrude each part of the motor and reassign correct physical definitions.
Otherwise, in general the workflow is very similar to an inner rotor. The only difference would be the sliding cylinder which should embed the rotor will have a different shape especially in 3D.
Cheers
