Hey guys,
I'm trying currently to run a heat transfer analysis where I have convection with ambiant temperature.
I checked the two tutorial (OS-T 1085 & OS-T 1090) and I feel like I'm doing everything as explained in it but it's not working.
When creating the convection, in the element selection part, I can select my solid element, and when I click on the 4 nodes to extract all the faces of the element, and then on the "add" button (with a break angle of 89°) nothing seems to happens.
On all the tutorial after this operation one can see the smaller square or triangle on the face of the element showing the surface/group just created but it just does not work for me.
In the mean time, in my freshly created group, I see that there are some element in the "slave entity IDs". The number seems pretty good, as if it worked properly, but impossible to have them displayed, and if I want to isolate them or show them, everything dissapear ...
I also have the same problem when I want to create a conduction in order to create a incoming heat flux through a surface...
Anyone could help me ?
Thanks for your support.
Pierre
