INTERNAL PROGRAMMING ERROR
Zafer_Cakir_54
Altair Community Member
I would like create a *.mnf file of a vehicle body-in-white in Optistruct . The problem is every time the program give me an Error message:
in file „dsetio-inc.h“, at location # 132
What does it mean? How can I fix the error?
Hello Zafer,
Could you please share the .out and .stat files from the model that is returning this error?
Thanks,
Vinicius Gomes0 -
This error is due to VERSION ISSUE , You might be given run in lower version and you did modelling in the higher version.
EXAMPLE: Using Hypermesh 2021.2 for modelling and while running in the solver you use 2019.
so, its version issue.
