Hi there,
Does hypercrash support 3d connexion? If so, how should I set up it? I am using hypercrash 2017.2.4.
Thanks.
Hi
Please try this:
- in the file 'HyperCrash.tcl' , located on the path <Altair_home_installation>\hwdesktop\hc\, remove the comment sign '#' on the line 123 that contains
# set env(HC_SPACEMOUSE) TRUE
becoming
Then, save the file and restart HyperCrash.
Please let me know if this helps you.
Regards
