My system got crashed which has Thea license installed in it. Can I log in again in the same system using the credentials again or it has to be deactivated before installing it? Please advise.
When you say "crashed" it means software or hardware.
License "node lock" is linked to your hardware. So if your hardware get running you can use again the credential.
