Hi, I have managed to set up a problem with converging results and would like some guidance or suggestions to improve my set up. I would like to optimise the structure to reduce the overall mass. I have attached screenshots of the results I have obtained and it doesnt seem quite right to me. I was expecting a truss-like structure so I was wondering if anyone has any suggestions or recommendations. I have tried changing some of the MINDIM, MAXDIM, element size and shape but i have had no luck.
 Just a summary of the problem setup.
 - This is a guide vane which has a concentrated load of 11kN applied at the leading edge.
 - SPCs on the bottom section
 - Volume limit of 0.3
 - Solid volume tetramesh
 - Shell surface 2D tria mesh (1mm thickness)
 - Objective set to minimise compliance
 - average element size 3mm
 - MINDIM 30 mm
 - MAXDIM 80 mm
