Hi, i tried a composite analisys and i trying to check if fail or not the component.
But the composit strenght ratio is the next.
Hi @tiago3008
The issue is with the MAT1 card which doesn't support any of orthotropic failure theories.
There is some failure theorie for MAT1 and MAT8?
I need to check a component with pvc foam and carbon fiber.
In order to get strength ratio when an iso material is used, make sure you provide ST, SC and SS (strength limits in tension, compression and shear) on MAT1 card.
These parameters are used for composite ply failure calculations. Please refer to help for more information.
Hi
I am doing composite laminate analysis
I have requested PARAM-SRCOMPS-YES, also CSTRESS from Global output request and SOUT-YES for all plies. I could see Composite Failure and Failure Index in Hyperview, but not the strength ratio. why ? I appreciate any help on this.
