I don't understand the reason of the following error: "FmHidenException: System error#12". It appears when I try to run a FluxMotor 2021 model from HyperStudy 2021.2. Please take a look to attached documents.
The FluxMotor model works correctly if I run the simulation outside HyperStudy.
When I run the same HyperStudy study in a different workstation, It works correctly.
Best regards,
Riccardo
