HyperStudy Error "Study was closed in an abnormal manner or is used by ( hst.exe )"
Riccardo Traversari
Riccardo Traversari Altair Community Member
edited March 2021 in Community Q&A
Hi everybody,
I've got some issue when I use HyperStudy 2020.1 with solver Flux 2018. The same problem occurs with another versions of the softwares too.
Sometimes, during optimization process, HyperStudy crashes and closes. When I open again the software, I can read following message error: "Study was closed in an abnormal manner or is used by ( hst.exe )". It seems a "random" problem, because it doesn't occur always; sometimes after some hours, but not always.
Please support me about this issue.
Best regards,
Riccardo
  • Diana_38240
    Diana_38240
    edited February 2021
    Hi Ricardo,
    Software crash should definitely not happen.
    To start investigating, can you look in the folder of the run when the crash occured and share the messages(if any) in the task_exe_stderr file ?
    I assume you have not you been able to identify a specific scenario in which the crash occurs ?
    Did you try with the latest 2021 releases HyperStudy and Flux?
    Finally it would be helpful if you can share the study archive so that we try to reproduce it.
    Diana
  • Riccardo Traversari
    The messages (multi-execution optimization with 2 jobs) are the followings:
    [62313|1612891993820|1|WARNING    ][UseCase|UseCaseManager.changeUseCase] : No use case transaction found
    [62313|1612892054517|1|WARNING    ][UseCase|UseCaseManager.changeUseCase] : No use case transaction found
    At the moment I cannot try the latest version of the softwares, but the same issue occurs with all the old versions of the softwares too.
    I'm sorry, but I cannot share the study.
    Thanks.
    Best regards,
    Riccardo
    Hi Diana,
    any news?
    FYI, this is the error message that I can read from Windows Event Viewer (general properties and details):
    "Faulting application name: hst.exe, version: 2020.1.0.0, time stamp: 0x5f4ed9a8
    Faulting module name: hwtemplex.dll, version: 0.0.0.0, time stamp: 0x5f4ed720
    Exception code: 0xc0000005
    Fault offset: 0x0000000000014a83
    Faulting process ID: 0x65c8
    Faulting application start time: 0x01d7010ced5604d5
    Faulting application path: C:\Program Files\Altair\2020\hwdesktop\hst\bin\win64\hst.exe
    Faulting module path: C:\Program Files\Altair\2020\hwdesktop\hst\bin\win64\hwtemplex.dll
    Report ID: 1017fe4a-2afd-4b3d-b30c-75f6d4035548
    Faulting package full name:
    Faulting package-relative application ID: "
    "<EventData>
    <Data>hst.exe</Data>
    <Data>2020.1.0.0</Data>
    <Data>5f4ed9a8</Data>
    <Data>hwtemplex.dll</Data>
    <Data>0.0.0.0</Data>
    <Data>5f4ed720</Data>
    <Data>c0000005</Data>
    <Data>0000000000014a83</Data>
    <Data>65c8</Data>
    <Data>01d7010ced5604d5</Data>
    <Data>C:\Program Files\Altair\2020\hwdesktop\hst\bin\win64\hst.exe</Data>
    <Data>C:\Program Files\Altair\2020\hwdesktop\hst\bin\win64\hwtemplex.dll</Data>
    <Data>1017fe4a-2afd-4b3d-b30c-75f6d4035548</Data>
    <Data>
    </Data>
    <Data>
    </Data>
    </EventData>
    </Event>"
  • Diana_38240
    Diana_38240
    edited March 2021
    Hi Ricardo.
    Sorry for the delay. Thanks for sharing these messages. I'll check internally and come back to you today.
    In the meantime it would be really helpful if you can upgrade the tools and try with the latest release 2021. Maybe you have already got the chance to do it?
    Diana
  • Diana_38240
    Diana_38240
    edited March 2021
    Ricardo,
    Could you please tell me which Windows version do you use?
    edited March 2021
    Hi Ricardo.
    Diana
    Hi Diana,
    I'll do it asap.
    edited March 2021
    Ricardo,
    Microsoft Windows 10 Enterprise.
  • Diana_38240
    Diana_38240
    edited March 2021
    Hi Ricardo,
    Could you tell me if you have linked variables which are disabled in your optimization study? I'm asking because we have noticed recently such issue recently and I wanted to check if you have such variables?
    Diana
    edited March 2021
    Hi Diana,
    I have linked variables which are disabled in my last optimization study, but tha same issue occurs when all the linked variables are active.
    Thanks.
    Best regards,
    Riccardo
  • Diana_38240
    Diana_38240
    edited March 2021
    Hi Ricardo,
    Thanks for the feedback. It does not look to be the same issue I was refering since you say it occurs also in the case of all variables enabled.
    For further investigation on your issue, it would be needed to get the archive of the study. To ensure the confidentiality I propose you to open a support request and share there the files rather than on the forum.  Like this we would be able to try to reproduce the issue and check with recent releases.
    Does that make sense for you ?
    Diana
