After running Hyperworks I have still one problem. The user interface is not pictured correctly (see the picture in the appendix). What is the mistake?
Johannes,
Open the command window of Hypermesh using view > command window
Please go to the working directory (by typing in pwd in the command window) and delete the settings files namely hmmenu.set, hmsettings.tcl, command.cmf and then try the same procedure,
Make sure you have a working directory created just for HW and then start your apps from there,
Make sure you have the recommended graphics cards and the recommended minimum driver version or higher installed, to see the recommended cards and driver versions, go to support > software downloads > documentation and choose the hardware requirements document. see below
