Finding surfaces and elements nearest to temporary nodes.
User: "Rachit Semalty"
Altair Community Member
Updated by Rachit Semalty
Hi all, I want to know if there is a way to associate nodes to nearest surfaces or elements within 3 mm from them using TCl code? Nodes may be attached to different surfaces or elements of different components. We don't know surface or element id initially. Also, is there any way to find out ids of surfaces and elements within 3mm from a node? hm_getnearbyentity does not seem to work properly when I tried to find nearest elements from nodes using sphere and box as well. It requires at least one node of element to be within the sphere and the resulting sphere is very big then. By box method is not working properly too.
Rachit
1 - 1 of 11
    User: "Adriano_Koga"
    Accepted Answer
    Updated by Adriano_Koga
    i think "by box" does not apply to surfaces.
    What about this command here?
    If your provide the coordinate of your temp node, and a list of all surfs, it should give you the id of the closest surface.
    hm_getcoordinatesfromnearestsurface
    Finds coordinates of a point that belongs to one of surfaces in input set and is a closest point to the location specified in command input.
    Syntax
    hm_getcoordinatesfromnearestsurface x y z surf_id_list
    Type
    HyperMesh Tcl Query Command
    This command finds the point on one of surfaces (specified by the list of surface IDs surf_id_list) closest to the point specified by coordinates x, y, z. The command returns the result as a list of four values. The first, second and third value in the list specify the x, y and z coordinates of the closest point correspondingly. The fourth value in the list is the ID of the surface on which the closest point is found.
    Inputs
    x
    The x coordinate.
    y
    The y coordinate.
    z
    The z coordinate.
    surf_id_list
    The ID of the surface on which the closest point is found.
    Example
    To find coordinates of the point on surface 12 that is closest to the location specified by x=1, y=3, z=5:
    hm_getcoordinatesfromnearestsurface 1 3 5 12
    On surfaces with IDs 12, 14, 15 find the point closest to global origin point (x=0, y=0, z=0):
    hm_getcoordinatesfromnearestsurface 0 0 0 [ list 12 14 15 ]
    To create node on surface with ID 10, closest to the point specified by x=1, y=3, z=5:
    set closest_pnt [ hm_getcoordinatesfromnearestsurface 1 3 5 10 ] set x [ lindex $closest_pnt 0 ] set y [ lindex $closest_pnt 1 ] set z [ lindex $closest_pnt 2 ] *createnode $x $y $z
