Hi all, I want to know if there is a way to associate nodes to nearest surfaces or elements within 3 mm from them using TCl code? Nodes may be attached to different surfaces or elements of different components. We don't know surface or element id initially. Also, is there any way to find out ids of surfaces and elements within 3mm from a node? hm_getnearbyentity does not seem to work properly when I tried to find nearest elements from nodes using sphere and box as well. It requires at least one node of element to be within the sphere and the resulting sphere is very big then. By box method is not working properly too.
Regards,
Rachit
