How to set up a composite analysis
Rahul_P1
Rahul_P1
to set up a composite analysis for OptiStruct, you might follow the following the steps within these tutorials:
http://training.altairuniversity.com/analysis/structural/composites/analysis-of-a-composite-plate-video/
http://training.altairuniversity.com/analysis/structural/composites/modeling-and-analysis-of-composite-structure/
There are more Tutorials available in the HyperWorks Help -> Tutorials -> Solver Tutorials -> OptiStruct
Please note that in order to write stress and failure data (e.G. Tsai-Wu) from an OptiStruct Composite Analysis, you need to activate the following solver input:
- The material (MAT 8 for shells) needs a statemend on the allowable Yield Limits for stress or strain
- The Property (Pcomp) or the Plies (in case of ply based modelling approach) need a statement for stress output --> SOUT = YES
- The Composite Stress and Strain output finally needs to be activated in the subcase options or globally for all subcases by using setup --> create --> control cards --> global output options --> CSTRESS and CSTRAIN
Please let us know, if you need further advice
Jan
Welcome!
  • Altair Forum User
    Altair Forum User
    edited March 2015
    I used to be able to set up a composite analysis in HyperMesh 12, but in HyperMesh 13 I can't retrieve the failure index results.
    I followed everything in the 'OS-4050: Optimization of a Horizontal Tail Plane' tutorial, but no matter whether I use HILL or TSAI (actually I would like to use TSAI) failure criteria, after the run is completed, in there is no 'Ply Failure' result in HyperView.
    I attached the file. Please rename the extension from *.txt to *.hm.
    Thank you
    Aecyd
  • Altair Forum User
    Altair Forum User
    edited March 2015
    What are the updates installed for HyperWorks on your machine?
    You can find the software updates and graphics information from HyperMesh>> Help>> Updates and system information
    http://forum.altairh...n-your-machine/
  • Altair Forum User
    Altair Forum User
    edited March 2015
    I've just updated to 13.0.211.
    However, after you asked the version I tried it with the 13.0.98 version, and it works.
    That seems to be a serious bug in the new version image/emoticons/default_sad.png' alt=':(' srcset='/emoticons/sad@2x.png 2x' width='20' height='20'>
  • Altair Forum User
    Altair Forum User
    edited March 2015
    Hi Aecyd,
    Add this line to solver deck through Unsupported_CARDS or you can edit the solver deck.
    CFAILURE(H3D,NDIV=1) = YES
    Manual edit:
    if you have requested CSTRESS for example, open the solver deck with a text editor and copy CSTRESS to another line. Now replace the CSTRESS (new line) with CFAILURE.
Welcome!
Welcome!
