ERROR:
In subcase # 1 of type 'NLGEOM':*** ERROR # 1459 ***Card 'NLPARM' is required for this subcase type.
If you have contact, then it is not a linear subcase and you have to define some parameters for the non linearity in your solver.
Create a load colector with the card: NLPARM, then:To do this you go into analysis -> loadstep -> and check NLPARAM and there you choose the NLPARAM Card you created.
Thank you for the answer. Now it works! Great!
Greets from http://www.ka-raceing.de
*** ERROR # 1459 *** in the input data: Card 'NLPARM' is required for this subcase type.
