For CBAR/CBEAM elements, normal stress at the cross-section origin is output by default, and is controlled by the STRESS I/O option.
Page Analysis-->ControlCards->Global_Output_Request-->Stress
If stress results are desired for other locations, the first continuation line for the PBAR/PBEAM definition is required. The maximum stress calculated at any of the four allowable stress recovery locations is then reported as the element's axial stress.
Note: If you are using PBEAML / PBARL the stress recovery points are predefined (see explanation about PBEAML/PBARL in the help menu)
Sectional forces and moments for 1-D elements can be obtained through the ELFORCE I/O option. If FORCE=YES is added to the I/O options section of the input deck, the .force file is output containing force and moment results.
Page Analysis-->ControlCards->Global_Output_Request-->ELFORCE
