Hihow can particular nodes displacement and stresses can be find in hyper view
Hi Syed,
you can do this using the query panel, Just go to results > query from the top pull down menu
and also the quick query option, just right click on the screen (graphics area) > go to quick query > then click on node (or element option) > then click on an actual node anywhere on the screen to see the contour value displayed on the screen.
Please see - HyperWorks Desktop Applications > HyperView > HyperView Tutorials > Querying Results > HV-4000: Querying Results as well.
One small detail is missing. To see the vector displacement in the query results.
Click on the vector and under plot select the components X Y Z and click apply.
Then under Query results you can see the vector displacement for GRIDS
