the Radioss Reference Guide states for LAW2 for field "ICC":
Strain rate computation flag 8
=0 (Default) Use default value
=1 Strain rate effect on
=2 No strain rate effect on
(Integer)
It is not clear to me what the value ICC=0 actually does. It should default to ICC=1 or ICC=2 because only these values have actual meanings.
Furthermore, it is stated for coefficient "c":
Strain rate coefficient c>=0
=0 No strain rate effect
Default = 0.00 (Real)
and in comment 8:
The ICC flag defines the effect of strain rate on the maximum material stress sigma_max. Figure 68 shows the value of for the corresponding ICC flag.
What is not clear to me is the behavior for the combination c=0 and ICC=1. The value c=0 disables strain rate effects on the yield stress curve while at the same time ICC=1 enables the strain rate effect on the maximum yield stress.
Are the two parameters c and ICC independent from each other or does c=0 imply ICC=1, ignoring the user input value?
Best regards
Rainer Immel
