I have a project to model laminar water flow in a simple pipe. The result I should obtain after the fluid travels a certain distance inside the pipe has been well documented in theory to appear in this parabolic form:
I began by making a pipe in Inventor with the diameter calculated from the Reynolds Number formula as R_e= (rho*velocity*diameter)/viscosity for R_e<20,000 for laminar flow. My inventor model is as shown below:
I imported my model into hypermesh and tried following tutorial CFD-1200 at the following link:http://www.altairhyperworks.com/(S(3fu2zyrlbyi03xcofiue25jd))/hwhelp/Altair/hw11.0/help/hwtut/hwtut.htm?hypermesh_tutorials.htm But when I obtained my results on hyperview, they didn't look anything like the predicted theoretical parabolic result. My result is shown below:
