is there a possibility to export screenshots of e.g. stress contour plots of my FEA results as vector graphics such as .eps files?
Best regardsDavid
You can do this easily with freeware, see the attached video that uses a free ware called pdf creator.
The video is only for demonstration, please check with pdf creator about its licensing and use. we cannot be responsible for external software and its effects. http://www.pdfforge.org/pdfcreator
If you make the pdfcreator for example the default printer, then you can use the keyboard shortcut of ctrl + f3 or ctrl + f1 to print from HyperView.
Note while saving you can choose the file format type to .eps, not doing so will save in the default pdf format.
