i have some trouble with the tutorial.
http://training.altairuniversity.com/structural/optimization/composites/composite-optimization-of-a-formula-student-monocoque/
in Section 2.2 Size-optimization setup -->Step 2: Editing the ply-shapes for later manufacturability
You edit the ply elements and i tried to do the same, but as i compare the results, i noticed some problems to get the same result. So please give me some advise for my questions.
The 1st point is: i can't select any element by window, geom etc. only by click on them. Each element on its own. is there any special i have to activate or tool i have to use?
The 2nd point is: it seems to me, that you just add some elements to the ply 12200. in the screen shots there are some holes in the ply. I got the same result at my trys. But i don't now how to add elements to an empty space or do you use functions, like you can use to clean a plane from holes? How do you do that?
And 3rd and last point for now is: is it possible to make a rule that for example the topply should not move or be optimised? because i have a carhood and i want to optimise it, but the top-ply should not be edited by the optimisation. Because if there is any change the face/design is gone.
Thank you.
Best regards.
Nils Englisch
