Hi guys,
in my size - free shape optimization is something going wrong. I'm optimizing a U-section (shell elements) and i created 2 layers inside this U-section with elm-offset. The first layer is the base layer and the second should be optimized with free shape, shrink only, grid con on the base layer. A size optimization works on the U-sections shell elements. The Layer material got a lower density then the U-section. Objective is to reduce mass.
But instead of strengthen the critical radius and reduce the shell layer size, the optimization moves the free shape layer near zero and doesn't change anything on the shell element size.
If i create a size - free shape optimization with only one layer the optimization runs normal and strengthens the radius.
Does somebody have an idea where my error is coming from?
