1. For unit consistency, if I'm using U.S. customary units, should I define all units based on lbm and inches? For example, for a downward force, would units of force be mg = lbm*386in/s^2? Or is lbf automatically interpreted in entering loads without the extra factor of 386 manually entered? I'm also concerned about this for entering stress values.
2. Is there a straightforward way to apply a GRAV card and point forces/moments to one loadstep? I've tried using a LOAD card but when the optimization is run an error states that no loads are referenced.
3. When applying forces to multiple nodes, is the value of force entered spread equally among the nodes selected? Or does is apply that force value to each node individually?
4. With a force constraint on multiple nodes, does the constraint apply to the sum of the forces on the nodes or does is just check the force on each individual node?
5. When multiple load cases are defined, how does OptiStruct compromise the different load cases to come up with a design that satisfies them all? (qualitative answer would be great!)
6. What would be the best way to set up a load case that extracts natural frequencies so that I may place a constraint on them?
