I m working on blowers with ACUSIM as my senior thesis and I have problems with reference frame definition. I started with a simple case like two coaxial cylinders one of them is turning on its own axis. Mesh is created and exported in HyperMesh 11. However i have a problem about interfaces. If i run the analysis without reference frame interfaces are working properly. But when i define a reference frame to a cylindirical volume, solver cuts out with an error as:
acuSolve: *** ASSERTION in Function <esvGetLocVelF> File <CompileDir/esvLocal.c> Line <145>
acuSolve: *** Not implemented
acuRun: *** ERROR: error occurred executing acuSolve
If i defined reference frame angular velocity is zero there is no error occures and solver runs properly.
I found tutorials about reference frame works in ACUSIM and made all steps clearly. Can you enlighten me about this issue.
