I want to calculate the drag coefficient of a simple CAD made car.
Therefor I create a huge cube around the car. My first conditions were left surface inflow and right surface outflow. The other surfaces were set to BC wall. I think this simulation works fine.´
In the next step I wanted to set three of the other four surfaces to BC FreeSurface and the last one to Wall.
No the first problem I want to solve: Every time I select one of the surfaces which are not the inflow and outflow AcuConsole always selects the four surfaces and not only one. So I am not able to select three of the four surfaces (pink surfaces).
The next problem I want to solve is: How can I calculate the area of the car which is normal to the velocity of the air?
I hope you understand my questions and you can help me with these problems above.
Best regard
Patrick
