i want to do a composite optimization and constrain in one region or on some elements the total laminate thickness or the thickness of the core ply because of not enough space in that region.
The whole laminate can have a total thickness of for example 25mm except these few elements, which should have a total thickness of 10mm.
I use shell elements and as objective minimize weighted compliance. The mass is constrained. I am in the Freesize Optimization Step.
How can i do that?
Of course i could constrain the total laminate thickness to 10mm everywhere, but i think this would not be the lightest solution.
Another question: Actually i want to minimize the weight by simultaneously complying a specific stiffness for a loadcase. So OptiStruct should decrease the mass, if the displacement/failure mode constraint is still fullfilled. Why is it done the other way round in every tutorial? What are the disadvantages doing it with minimize mass as objective?
Thank you very much for your help.
