Hi
I would like to implement a methode in Optisruct (hypermesh version 11) who can delete elements on my own methode. The methode shuld calculate utilization by FKM.
It is impossible and has anywhere a idear how I can do this ?
chris
functions from external routines can be used in OptiStruct by using the DRESP3 Keyword and programming in HyperMath, C or Fortran. The general procedure is described in the OptiStruct help, chapters:- External Responses- DRESP3
There also is a tutorial describing the way to include external responses in OptiStruct (for size optimization instead of topology, but the procedure should be the same):- OS-4095: Size Optimization using External Responses (DRESP3) through HyperMath
The described way through HyperMath should be the easiest, as no compilation of the script is needed.
Kind RegardsJan
