I had a question when I was learning EDEMAPI Tutorial 1 - Particle Replacement and trying to implement particle replacement in EDEM. There is a file 'Particle_Cluster_Data' in this tutorial, which basically about a particle will be replaced by how many meta-particles. However, I have no idea how the coordinates of each meta-particle were obtained. Could you please explain to me how these coordinates were obtained?
Many thanks,
Chao
