Altair RISE
Nominate Yourself Now!
Unable to create any clients. Check the license file.
User: "Rahul_P1"
Updated by Rahul_P1
Hi i have a problem with my license file. it gives me 'Unable to create any clients. Check the license file.' error. at first my ethernet id was 000000000 so i talk with you guys and asked for the help, then one of your college said to connect my laptop to the modem using the cable in that way my local network id will be activated. i have done this and asked for the new license file. but now i have new problem. hyperworks works only when my pc is connected to modem by cable, without it (like when i am using wifi) it gives me that error. what should i do? is there any way to active my local network without connecting it with cable??
1 - 1 of 11
    User: "Rahul_P1"
    OP
    Updated by Rahul_P1
    hldk64
    The basic Idea is to identify a physical address that will always be active,
    Try the below -
    Press the 'Windows' and 'R' keys together to open the run window.
    Type 'Devmgmt.msc' in Run and click 'OK' to open the Device Manager.
    Click the arrow next to 'Network adapters.' This will expand all network devices installed on the computer.
    Right-click the LAN adapter(the adapter whose ethernet id you used) and click 'Enable.'
