I wish to use the "make current" part.
But I did not see the menu.
How can I use the "make current" buttron?
Thank you in advance for your response.
Hi Kwangsu Kim,
I can see the make current option in the V2023.1. Please try the following steps and reopen the HyperMesh
1. Delete all the. tcl files from the DOCUMENT FOLDER2. Search %userprofile% through the Windows search bar to open the location and delete the 2 folders mentioned below 1 - .altair 2 - .installanywhere folder
Sriramanuj Prabhu
Hello, Sriramanuj Prabhu
The problem has not been solved.
I unlocked the active box in the current part and pressed OK.It is believed that the problem has occurred since then.
Is there anything else I need to review?
Thanks,
Hello, Sriramanuj Prabhu The problem has not been solved. I unlocked the active box in the current part and pressed OK.It is believed that the problem has occurred since then. Is there anything else I need to review? Thanks,
I found the cause.
